Communauté Informatique NDFR.net : Winamp 5.03 - Actualité
Winamp 5.03
Old 25-03-2004, 19:09
Winamp 5.03
Lien direct de la news : Winamp 5.03
Bien que pas encore annoncée sur le site officiel, la dernière version de Winamp, la 5.03, est disponible sur le site de téléchargement de Nullsoft.
Le changelog :
  • made MP4 AAC the new default ripping encoder
  • fixed a crash bug when playing some AVI files in in_dshow
  • added multimedia keyboard keys in global hotkeys default configuration
  • added "Manual playlist advance" in Repeat button popup menu in Classic mode
  • improvements in MP3 encoder configuration (added --alt-preset standard, etc...)
  • made the tabs in the preferences XP correctly themed under Windows XP
  • revamped the Media Library preferences a bit
  • new experimental WMA9 input plugin
  • gen_jumpex updates from DrO
  • added "Nuke library" action in Media Library
  • more upside down videos fixes
  • fixed crash if a plugin generated a pledit wm_windowposchanged on shutdown
  • fixed crash exploit in in_mod (thanks Peter Winter-Smith)
  • fixed various crashes in in_midi when playing invalid files
  • made in_midi store its settings in winamp.ini instead of the registry
  • fixed error during installation on computers with chinese/oriental regional settings
  • removed AOD from installer
  • added Shift-R to toggle manual playlist advance
  • updated VP6 video decoder to latest VP6.2 code
  • fixed crash when launching winamp with very long filenames from explorer
  • made registration dialog to appear in Explorer's taskbar when installing pro version
  • fixed pledit/video windows showing up at startup when minimized
  • modern skins updates:
    • winamp modern skin now uses a 3 state repeat button: no repeat/repeat all/repeat track
    • added appplication desktop toolbars capabilities for layouts, add
      appbar="left|top|right|bottom" to use them
    • upped maki binary version, improved stack protection
    • current skin version number is 1.2 (this should not change for a long while now, and of course we continue to support 0.8 to 1.1)
    • (very) limited maki debugger (for now you can bring it up with invokeDebugger(); in a script then use 'x' to continue and 'i' to trace into)
    • fixed obscure capture problem with dragging windows
    • fixed rectrgn being forced to 1 in xml xuiobject buttons that are originally imageless
    • fixed hilited state not on after clicking on buttons while the mouse stays in area
    • fixed scripted onEnterArea/onLeaveArea not being always correctly called while mouse button stays down
    • fixed getToken being passed NULL throwing guru
    • fixed clipping of painting within the background's region of a group rather than within the composed region (the one you can change with sysregion)
    • fixed image cache problem when using the same bitmap as a map and a button image parameter
Télécharger Winamp 5.03 Full (4,20 Mo)
Télécharger Winamp 5.03 Lite (649 Ko)
Source : Neowin.net
Old 25-03-2004, 21:05
Fred's Avatar
Fred Fred is offline
00 Agent
Re: Winamp 5.03
Domage que Winamp2 ne soit plus mis à jour, Winamp3 est trop gourmand pour tourner correctement sur ma machine, et intègre des tas de fonctions dont je n'ai pas besoin ...
... non Gaston
Old 25-03-2004, 21:34
streets's Avatar
streets streets is offline
KiLL BiLL
Re: Winamp 5.03
il parle de winamp 2+3
euh 5.03 plus exactememt
donc la 3 aux oubliettes
Old 25-03-2004, 21:38
Re: Winamp 5.03
Oui, mais la 5 aussi est bien plus lourdes que la 2 ... Chez moi elle met plusieurs secondes à s'afficher, alors que WinAmp 2 s'affichait quasi-instantanément ...
Old 25-03-2004, 21:40
Re: Winamp 5.03
toujours aussi lente que la 5.02 ? moi g complètement abandonné, g laissé au cas ou, mais foobar2000 c le top
Old 25-03-2004, 22:05
KnuX's Avatar
KnuX KnuX is offline
Re: Winamp 5.03
Personnellement je n'ai eu aucun soucis avec la version 5.x hormis le "Always on top" qui laiss(ait/e) à désirer, et parfois un winamp.exe encore présent dans les processus malgré qu'il soit fermé (j'avais ça sur la 2.x).
Je viens d'installer cette nouvelle version
http://max.skyrock.com/
Old 25-03-2004, 22:28
streets's Avatar
KiLL BiLL
Re: Winamp 5.03
je dirais meme plus foobar 2000 c'est le top
+mpc pour la video
Old 26-03-2004, 00:24
Fred's Avatar
00 Agent
Re: Winamp 5.03
Excusez le lapsus, je voulais bien entendu parler de la v5, qui est trop lourde pour nous autres, pauvres petites configs auquelles la v2 suffit amplement
... non Gaston
Old 26-03-2004, 01:27
Re: Winamp 5.03
Même sur des configs plus musclées, la 2 reste nettement plus agréable à utiliser ... J'pense que j'vais pas tarder à y retourner ^^
Old 26-03-2004, 11:41
dubois dubois is offline
Re: Winamp 5.03
restez en version 2 c'est mieux et légé
Old 26-03-2004, 12:17
Re: Winamp 5.03
Moi je reste à la version 5, beaucoup plus agréable à l'oeil
Old 28-03-2004, 10:36
benoit1024's Avatar
benoit1024 benoit1024 is offline
Send a message via ICQ to benoit1024
Re: Winamp 5.03
la 5 à tout de même pas mal de bonne fonctionnalités et est pour ma part très stable.
la médiathèque est top
_oO0° Ben °0Oo_
Old 28-03-2004, 13:12
whynot's Avatar
whynot whynot is offline
Re: Winamp 5.03
Hmmm... si wa5 est lent, c'est aussi à cause des "moderns skins" et des tonnes de fonctions -inutiles pour certaines- qu'il trimbale...
En mettant un bon vieux skin wa2 et en désactivant quelques plugins c'est déjà un peu moins lourd à lancer et ça devient supportable en utilisation mémoire.
Ceci dit, j'ajouterais que foobar2000 c'est le top.
Old 03-04-2004, 03:13
gelflings gelflings is offline
Re: Winamp 5.03
bonjour à tous
en ce qui concerne Winamp je comprends pas pourquoi vous n'instalez pas la 5 (5.03) et dans l'install vouss virez l'agent , les skins moderne et autre conneries que vous n'aimez pas genre raccourcis claviers tout ça, la video etc
Car la mediatheque est top et winamp le coeur est vraiment optimisé maintenant
faites le tests (avis aux amateurs de la 2) vous serez satisfait je pense
Foobar 0.8.1 beta 3 - WinAmp 5.03a LeMoi Actualité 0 01-04-2004 01:12
WinAmp 5.0 Finale streets Actualité 50 26-12-2003 23:40
Après la RC2 la RC8 de WinAMP 5 Werner Actualité 8 21-11-2003 19:00
Winamp 5 beta 2 streets Actualité 0 29-10-2003 01:42
WinAmp 2.90 Beta & WinAMP 3 Build 498 Werner Actualité 16 03-04-2003 05:02
